Author Topic: hot tub buying  (Read 7274 times)
kztahoe
hot tub buying
« on: May 27, 2004, 01:17:12 pm »
we have been shopping and researching a tub purchase. So far, we like the HS Vanguard. I (female) also wet tested the Marquais Euphoria. Now I don't know what to do. There are some things different on both that are appealing one way or another. We have never owned a tub so I know we will be happy with either, but don't want to have any regrets. What to do??? Pleez help...........
hot tub buying
Chris_H
Re: hot tub buying
« Reply #1 on: May 27, 2004, 01:23:55 pm »
kztzhoe:
I would recommend both manufacturers.  Did you wet test both?
One thing to maybe help decide is to ask the salesmen if they charge a "per-trip" charge if your spa needs service.  If one does and one doesn't that may help decide which local dealer is the right one for you.
Chris H
Re: hot tub buying
« Reply #2 on: May 27, 2004, 03:54:17 pm »
They both are tubs with good reputations.  Keep looking at them both and see if one dealer suddenly makes an offer you can't refuse.
Lori
Re: hot tub buying
« Reply #3 on: May 27, 2004, 05:00:49 pm »
For my final decision, I wet tested the top 2 tubs back to back.
Sure helped with my decision.  It was still difficult!
You are right, though, you will be happy with either tub.  I'm a little prejudiced, I have no regrets for my choice.
Good luck!
Mendocino101
Re: hot tub buying
« Reply #4 on: May 27, 2004, 09:38:27 pm »
Those are two very nice spas...Each has their fans here on this board...(I am bias towards the Marquis)...as others have said wet test to see what you like the best...and if they are close...I would go with the dealer you like better...You will not make a bad choice with either one....
Re: hot tub buying
