Author Topic: 5 0r 6 person?  (Read 13053 times)
mowgli
5 0r 6 person?
« on: May 20, 2004, 09:09:46 am »
considering the Hot Springs Vista versus Hot Springs Grandee...they seem to be the same spa with the only real difference being the # of people that the tub is designed for and a price difference of roughly $1000.  Any thoughts on the real use---5 or 6 person!  I have a wife and 3 growing kids 20, 16,13!  Also should i look at another brand as these seem pricey?
5 0r 6 person?
Re: 5 0r 6 person?
« Reply #1 on: May 20, 2004, 09:24:37 am »
Only you will be able to decide what the right size spa is for you.  We went with a larger capacity, becase we like to entertain.  Mostly it's just the wife and I, but often we have up to 6 or 8, so for us it's nice to have the space.  You have to decide what's right for you.
Hot Springs is a top brand, and all top brands will be at the upper end of the price range, and for good reason.
Shop around to see many different brands, and be sure to test out any spa you are seriously considering by hopping in the water.
Re: 5 0r 6 person?
« Reply #2 on: May 20, 2004, 11:53:37 am »
considering the Hot Springs Vista versus Hot Springs Grandee... Any thoughts on the real use---5 or 6 person!  I have a wife and 3 growing kids 20, 16,13!
The big difference is one has a lounge and one does not. IF you think all 5 of you will often be in it at the same time then the one without the lounge will certainly give you more space. IF you'll all use it but not necessarily at the same time then either would do you fine. A wet test often gives you insight as to which you truly want when you're unsure.
« Last Edit: May 20, 2004, 11:54:14 am by Spatech_tuo »
Re: 5 0r 6 person?
