Author Topic: interesting heat loss  (Read 2770 times)
benalexe
« on: January 16, 2009, 04:16:35 pm »
My Tub has been at 102 since Christmas.   I have not been using it that much and probably will not for at last 2 weeks. I turned the temp down this morning from 102 to 80 degrees.   It is one of the coldest days of the year right now and i check the tub.  in about 8 hours it lost very little heat. Went from 102 to 97.  I thought that was pretty good.
cburk0677
Re: interesting heat loss
« Reply #1 on: January 16, 2009, 04:22:02 pm »
What brand and model of hottub do you have? Is it full foam?
Enjoying SpaTopia in my 2006 Hotspring Vanguard
Hillbilly Hot Tub
« Reply #2 on: January 17, 2009, 11:49:44 am »
In a 12 hour span in ECN mode, I loose about 2-3 degrees in sub zero temps.
Be carefull turning your tub down low, if you have a power outage you are now 22 degrees closer to freezing, just keep it in mind.
