Author Topic: Disconnected tub in spring temperatures  (Read 3213 times)
lagator43
  • My wings are a shield of steel.
« on: April 01, 2008, 04:36:16 pm »
I live in Edmonton Alberta and the temp is ranging anywhere from +7 degrees to - 7 degrees celsius.  I am moving and need to disconnect the electrical 10 days before I can move the tub.  Will this harm the pump and/or jets?  I am worried about the water that gets left in the system after I drain it freezing.
I was hoping for warmer temperatures but spring has been on the chilly side so far.  Any advice?
« Last Edit: April 01, 2008, 04:45:30 pm by lagator43 »
BauerN
  • "...to feel is to believe."
Re: Disconnected tub in spring temperatures
« Reply #1 on: April 01, 2008, 04:50:20 pm »
It probably will not do damage (depending on what temperatures are actually reached, and for how long), but I would remove all of the water I could (shop vac is great for this, if you have one), and undo the lower unions on the pumps.
Even if damage is unlikely, it could cost a few dollars, not to mention headaches.
If you're not up to the D-I-Y, you should be able to hire a tech for this service, for (hopefully) a reasonable price.
Bullfrog Spas Dealer.  Raising the bar for customer service.
