Author Topic: Bromine to Dichlor  (Read 3442 times)
Steelerpete
Bromine to Dichlor
« on: November 24, 2007, 11:53:51 am »
I drained my tub a couple weeks ago to switch sanitizers and couldn't get the last inch or two of water out of the tub. So I filled the tub anyways and I have about a 400 gallon tub, I have some of my old Bromine stripes left over so I thought I would use them to measure PH and Alk and I noticed that I was getting a Bromine reading even though I'm using Dichlor. Is this because I didn't drain the tub right dry? Is this common? Or are the chemicals close in property's to give the reading? I also noticed that when I was on Bromine when I gave the tub a shot of granular Bromine it would show some free chlorine on the test strips I was using at the time that had Bromine/Free chlorine/ PH/and Alk. Any help would be great. :-/ :) :)
Bromine to Dichlor
TubsAndCues
Re: Bromine to Dichlor
« Reply #1 on: November 24, 2007, 12:06:45 pm »
Chances are good that you're fine.  Bromine and chlorine are very close chemically and you will very likely get false readings if testing for both.
tony
  • 2002 Optima
« Reply #2 on: November 24, 2007, 02:40:48 pm »
Yup, even though you are using bromine strips, you are actually measuring chlorine...and it works the other way too.
Steelerpete
« Reply #3 on: November 24, 2007, 05:12:42 pm »
Thanks for the info!!!! :) :) :) :)
Dr. Spaâ„¢ Ret.
« Reply #4 on: November 25, 2007, 08:27:41 pm »
Test strips don't measure chlorine or bromine...... They measure the oxidation potential of the water. Bromine strips then convert the "oxidation potential" reading  into a bromine ppm. Chlorine strips will convert the "oxidation potential" reading into a chlorine ppm. Bromine [chlorine] test strips will register the "oxidation potential" of chlorine [bromine], but their reading (color change) wont indicate anything understandable to you (other than there's something oxidizing in your water :) ). The test strips are specifically calibrated to the substance they're designed to test...... by the way, chlorine/bromine test strips will also register for non-chlorine shock (MPS).
