Author Topic: New test results  (Read 6465 times)
Chad
  • 2006 Jacuzzi J-345
New test results
« on: August 04, 2007, 08:34:20 am »
Ever since I cleaned the lines of my circ pump and ozonator and mounted my Hartford loop above the waterline, I've noticed a stronger presence of ozone gas and ALOT more water/bubbles coming out of the port. So with these increases, I figured why not put my N2 and ozone to the test. Well I did. Last Saturday I added a 5 ppm dose of dichlor. I soaked everyday but one from then until today. I didn't add any dichlor all week and my water remained clear as new and had now signs of CC.
My test results this morning were 0ppm for all chlorine levels(atleast to my naked eye) and pH was right where it's been the last month(7.4). :)
Granted I do shower before almost all my soaks but I'm still pretty impressed with these results.
Btw, do not atempt this if you are new to water care maintenance.
« Last Edit: August 04, 2007, 08:37:57 am by WHY_NOT »
New test results
Re: New test results
« Reply #1 on: August 04, 2007, 10:13:22 am »
A young, single guy soaking alone ... my life isn't so bad after all! ;) ;D
How and where did you clean out your lines? Are you talking about the line from the ozonator to the mazzi injector?
Did you have a Hartford loop already but just too low?
Experimenting with your tub, I'm starting to rub off on you ain't I!!  8-)
Chad
« Reply #2 on: August 04, 2007, 10:39:22 am »
 ;D Yeah it's been lonely around here lately.  :-[
I disconnected the lines you mentioned above and soaked them in vinegar water and  used a pipe cleaner. The Hartford Loop was already there but was well below the waterline. Tony gave me some great advice and really made everything a breeze. It flows better now than it ever has.
Yep, you're the one that got me where I am today, so it's only right to keep following in your foot steps. :)
« Last Edit: August 04, 2007, 10:40:16 am by WHY_NOT »
« Reply #3 on: August 04, 2007, 04:18:16 pm »
Now quit showering before use,see if it changes.  I never shower before use unless I have been out doing yard type stuff which on 6 acres can be alot.
« Reply #4 on: August 04, 2007, 04:21:30 pm »
The heck with that - start having s*x in the tub and see if it changes. Remember he's young and single! ;D
Dr. Spaâ„¢ Ret.
« Reply #5 on: August 04, 2007, 04:31:12 pm »
I'm sure six people in the tub would make quite a difference.
« Reply #6 on: August 04, 2007, 04:48:19 pm »
You're correct, between not showering and having six people in the tub his chemistry wouldn't be so good.
Then again if he didn't shower would you get 5 more people in the tub with him?
« Last Edit: August 04, 2007, 04:48:53 pm by Vinny »
Chad
« Reply #7 on: August 04, 2007, 05:29:12 pm »
 ;D ;D
With all the thinset, grout, mastic, and sawdust that always find a way to stick on me at work, I have to take a shower before soaking. Those things can't be good for the plumbing, heater, pumps, etc....
The only people in my tub since I've had it(10 months) have been female. Wow, I just realized that. I guess soaking in hot water in a bathing suit at night with a guy friend never really crosses my mind. Sadly though, I've only had 6 different females in my tub. I had 4 in there with me over the winter but nothing to exciting since. It's usually just me and my gal on the weekends and just me during the week. She's down in FL visiting her parents right now, so I might call those 4 "lady friends" tonight........ ;D
hottubdan
« Reply #8 on: August 04, 2007, 06:11:54 pm »
;D ;D
Does she read this forum? :D ;) :) ;D
Chad
« Reply #9 on: August 04, 2007, 06:14:39 pm »
I sure hope not. Maybe I should I switch my username back to WHY NOT just to be  safe.  8-)
« Last Edit: August 04, 2007, 06:15:24 pm by WHY_NOT »
Cyn
« Reply #10 on: August 04, 2007, 07:09:47 pm »
Not much of a night in STL for hot tubbing!!
Chad
« Reply #11 on: August 04, 2007, 07:20:01 pm »
You got that right. I'm waitin for the sun to set a little, so I can finally cut my grass. Last I checked the heat index was still over 100. :'(
What part of the STL are you from?
Cyn
« Reply #12 on: August 04, 2007, 07:21:32 pm »
...and it is supposed to get worse everyday this week.
Chesterfield.  Where are you?
Chad
« Reply #13 on: August 04, 2007, 07:32:01 pm »
Across the Daniel Boone in St. Charles.
Cyn
« Reply #14 on: August 04, 2007, 07:33:23 pm »
Is Heather your dealer?
